关键词:工业控制 马达控制 CAN Maxim MAX33042E
时间:2021-03-12 13:45:55 来源:中电网
Maxim公司的MAX33042E是5V 4Mbps CAN收发器,具有±40V故障保护和±25V CMR以及±40kV ESD,超过ISO 11898-2 CAN标准-2V到7V指标.器件工作在高速CAN数据速率,短距离网络速率高达4Mbps.器件具有短路保护,发送器域暂停防止锁定和热关断.器件提供了灵活设计选择,器件具有慢转换速率以最小化EMI.低电流待机模式,关断引脚节省功耗,工作温度-40C到 +125C.8引脚SOT23封装.主要用在工业设备,仪表,马达控制和建筑物自动化.本文介绍了MAX33042E主要优势和特性,简化框图,多站CAN总线框图以及评估板MAX33042E EVK主要特性,电路图,材料清单和PCB设计图.
The MAX33042E is a +5V CAN transceiver with integrated protection for industrial applications. This device has extended ±40V fault protection for equipment where overvoltage protection is required. It also incorporates high ±40kV ESD Human Body Model (HBM) protection and an input common-mode range (CMR) of ±25V, exceeding the ISO 11898-2 CAN standard of -2V to +7V. This makes it well suited for applications where there is moderate electrical noise that can influence the ground levels between two nodes or systems.
This device operates at a high-speed CAN data rate, allowing up to 4Mbps on short distance networks. Maximum speed on large networks may be limited by the number of nodes, the type of cabling used, stub length, and other factors. The MAX33042E includes a dominant timeout to prevent bus lockup caused by controller error or by..
分享到:
