关键词:消费类电子 马达控制 工业自动化 HVAC Infineon IM535-U6DMini600V
时间:2020-12-31 12:10:40 来源:中电网
Infineon公司的IM535-U6D是CIPOS™ Mini 600 V 30 A三相TRENCHSTOP™ IGBT,基于智能功率模块和开路发射极,采用DIP 36x21D封装. IM535-U6D提供全特性的紧凑的逆变器带DCB衬底解决方案,具有极好的热特性.基于TRENCHSTOP™ IGBT和抗并联二极管,优化的SOI栅极驱动器,以及极好热导性和电绝缘,从而具有更高的功率能力.器件具有30A逆变器电流额度,集成了自举功能,过流关断,在保护时所有6个开关关断,所有通路具有欠压锁住.器件具有睡眠功能,防止交叉导通,10kHz时的马达额定功率高达3000W,满足UL认证.主要用在供热通风与空气调节(HVAC),家用电器,工业自动化,马达控制和驱动.本文介绍了IM535-U6D主要特性和优势,内部电路图,典型应用电路图以及评估板EVAL-M1-IM535主要特性和电指标,框图,电路图,材料清单和PCB设计图.
CIPOS™ Mini 600 V, 30 A three-phase TRENCHSTOP™ IGBT based intelligent power module with open emitter in DIP 36x21D package. It provides fully featured compact inverter solution with DCB substrate to enable excellent thermal performance. Moreover, it enables higher power capability based on Infineons leading-edge TRENCHSTOP™ IGBTs and anti-parallel diodes together with optimized SOI gate driver along with excellent thermal conduction and electrical isolation.
IM535-U6D主要特性:
Based on TRENCHSTOP™ IGBT
30 A of inverter current rating
Rugged SOI gate driver technology
Integrated bootstrap function
Over current shutdown
All of 6 switches turn of..
分享到:
