Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´]Maxim MAX20340Ë«ÏòDC¶¯Á¦ÏßͨÐŹÜÀí½â¾ö·½°¸
¹Ø¼ü´Ê£ºÓÐÏßͨÐÅ ¶¯Á¦ÏßͨÐÅ PLC ¿É´©´÷ POS Maxim MAX20340
ʱ¼ä£º2020-08-18 12:25:23       À´Ô´£ºÖеçÍø
Maxim¹«Ë¾µÄMAX20340ÊÇͨÓÃË«ÏòDC¶¯Á¦ÏßͨÐÅ(PLC)¹ÜÀí¼¯³Éµç·,×î´ó±ÈÌØÂÊΪ166.7kbps,Æ÷¼þµÄ×î´ó³äµçµçÁ÷Ϊ1.2A. Æ÷¼þ¾ßÓдÓÖ¸Ïòµç·,µ±PLCÖ÷¼ì²âµ½ÔÚ¶¯Á¦ÏßÉÏ´æÔÚPLC´ÓʱÄܶÔϵͳ½øÐÐÖжÏ.ÕâÖÖ¹¦ÄÜʹµÃϵͳ±£³ÖÔڵ͹¦ºÄ״ֱ̬µ½´ÓÉ豸±»Á¬½ÓÉÏ.MAX20340µÄÐí¶àÌØÐÔÈçÖ÷/´Óģʽ,I2CѰַ,˫·/µ¥Â·PLC´ÓģʽºÍPLC´ÓµØÖ·ÊÇÒý½Å¿ÉÅäÖõÄ.Æ÷¼þ²ÉÓÃ1.358mm x 1.358mm WLP·â×°.Ö÷ÒªÓÃÔÚÕæÕýµÄÎÞÏß¶úÈû,ÓÐÏßÎÞÏß¶ú»ú,ÖúÌýÆ÷,¿É´©´÷,ÓÎÏ·¿ØÖÆÌ¨,ÊÖ³ÖÎÞÏßµçºÍÏúÊÛÖÕ¶Ë(POS)É豸.±¾ÎĽéÉÜÁËMAX20340Ö÷ÒªÓÅÊÆºÍÌØÐÔ,¹¦ÄÜ¿òͼ,´øµõ¼ÜÎÞÏß¶úÈû³äµç·ÒÔ¼°ÆÀ¹À°åMAX20340 EVKÖ÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
 The MAX20340 is a universal bidirectional DC powerline communication (PLC) management IC with a 166.7kbps maximum bit rate. The device is capable of a maximum of 1.2A charge current.
The MAX20340 features a slave detection circuit that flags an interrupt to the system when the PLC master detects the presence of a PLC slave on the power line. This function allows the system to remain in a low-power state until a slave device is connected.
Many of the features of the MAX20340, such as master/slave mode, I2C address, dual/single PLC slave mode, and PLC slave address, are pin configurable.
The device is available in a 9-bump, 0.4mm pitch, 1.358mm x 1.358mm wafer-level package (WLP).
MAX20340Ö÷ÒªÓÅÊÆºÍÌØÐÔ:
.txt_po{ color:#FFFFFF;text-align:center; cursor:pointer; border:1px solid #C41618; width:180px; height:35px; margin-top:20px; -moz-border-radius: 5px; -webkit-border-radius: 5px; border-radius: 5px; } .txt_po a{ text-decoration:none; color:#C41618; display:inline-block; padding:8px 6px; font-size:20px; line-height:30px; } .txt_po img{ vertical-align:sub; } .txt_po a:hover{ color:#C41618;}
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
