Maxim公司的MAX17523/MAX17523A是业界最小的和强健的集成系统保护解决方案,可调过压和过流保护器件非常适合正和负输入电压故障高达±40V的系统保护,具有190mΩ(典型值) RON集成的FET. MAX17523的可调过压范围在6V和36V之间,而可调欠压范围在4.4V和24V之间.过压锁住(OVLO)和欠压锁住(UVLO)阈值是33V(典型值),而目前的内部UVLO阈值为19V(典型值). MAX17523/MAX17523A可编程电流限值保护高达1A.器件可设定自动重试,栓锁或连续故障响应
Maxim公司的MAX17523/MAX17523A是业界最小的和强健的集成系统保护解决方案,可调过压和过流保护器件非常适合正和负输入电压故障高达±40V的系统保护,具有190mΩ(典型值) RON集成的FET. MAX17523的可调过压范围在6V和36V之间,而可调欠压范围在4.4V和24V之间.过压锁住(OVLO)和欠压锁住(UVLO)阈值是33V(典型值),而目前的内部UVLO阈值为19V(典型值). MAX17523/MAX17523A可编程电流限值保护高达1A.器件可设定自动重试,栓锁或连续故障响应当过流情况发生时.一当电流达到阈值, 在设定自动重试模式时,MAX17523/MAX17523A在21ms消隐时间后就关断,并在重试周期保持关断.当设定栓锁模式器件在消隐时间后就关断.当设定连续模式器件就连续限制电流. MAX17523/MAX17523A还具有反向电流和热关断保护特性.器件采用小型16引脚3mmx3mm TQFN封装,工作温度-40°C 到 +125°C.主要用在传感器系统,条件监视,工作传感器,过程分析,生产过程用检测仪以及称重和配料系统.本文介绍了MAX17523A主要优势和特性,功能框图, 典型应用电路图以及评估板MAX17523A EVK主要特性,电路图,材料清单和PCB设计图.
The Olympus series of ICs are the industrys smallest and robust integrated system protection solutions. The MAX17523/MAX17523A adjustable overvoltage and overcurrent protection devices are ideal for protecting systems against positive and negative input voltage faults up to ±40V, and feature low 190mΩ (typ) RON integrated FETs.
The adjustable overvoltage range in MAX17523 is between 6V and 36V, while the adjustable undervoltage range is between 4.4V and 24V. The adjustable overvoltage range in MAX17523A is between 6V and 36V, while the adjustable undervoltage range is between 4.2V and 24V. The overvoltage-lockout (OVLO) and undervoltage-lockout (UVLO) thresholds are set using optional external resistors. The factory preset internal OVLO threshold is 33V (typ), and the preset internal UVLO threshold is 19V (typ).
The MAX17523/MAX17523A also feature programmable current-limit protection up to 1A. The devices can be set for autoretry, latch-off, or continuous fault response when an overcurrent event occurs. Once current reaches the...
