[原创] Microchip USB7216六端口USB 3.1 Gen 2 Type-C控制方案
关键词:USB Type-C PC机 USB7216
时间:2020-04-17 11:22:13       来源:中电网
Microchip公司的USB7216是低功耗OEM可配置的六端口USB 3.1 Gen 2 Type-C控制器集线器,适用于嵌入USB应用. USB7216完全和USB Revision 3.1指标与USB 2.0 Link功率管理补篇兼容,支持10 Gbps超级速率+(SS+),5Gbps超级速率(SS),480Mbps高速(HS),12 Mbps全速(FS)和1.5 Mbps低速(LS) USB下行设备,具有四个USB 3.1 Gen 2下形端口和HS/FS/LS两个标准USB 2.0下行端口.片上微控制器管理I/O,VBUS和其它信号,集成了96kB RAM和256kB ROM,8kB OTP ROM和片上电荷泵以及通过OTP ROM,SPI外接存储器或SMBus配置编程.主要用在标准USB集线器, 笔记本坞站,PC主板,PC监视器坞站,多功能USB 3.1 Gen 2外设.中电网为您整理如下详细资料,本文介绍了USB7216亮点和主要优势,内部框图-上行Type-B应用以及评估板EVB-USB7216主要特性,框图,电路图,材料清单和PCB设计图.
The Microchip USB7216 hub is a low-power, OEM configurable, USB 3.1 Gen 2 hub controller with 6 downstream ports and advanced features for embedded USB applications. The USB7216 is fully compliant with the Universal Serial Bus Revision 3.1 Specification and USB 2.0 Link Power Management Addendum. The USB7216 supports 10 Gbps Super-Speed+ (SS+), 5 Gbps SuperSpeed (SS), 480 Mbps Hi-Speed (HS), 12 Mbps Full-Speed (FS), and 1.5 Mbps Low-Speed (LS) USB downstream devices on four standard USB 3.1 Gen 2 downstream ports and only legacy speeds (HS/FS/LS) on two standard USB 2.0 downstream ports.
查看全文
