[原创] Cypress CYW20706单片蓝牙(BT)双模式SoC解决方案
关键词:ARM Cortex-M3 MCU 无线通信 蓝牙 系统级芯片(SoC)
时间:2020-03-25 11:56:09       来源:中电网
Cypress公司的CYW20706是单片蓝牙(BT)双模式系统级芯片(SoC),集成了基带处理器,ARM® Cortex™-M3处理器和集成的收发器.它是运行于嵌入BT堆栈,支持采用WICED Studio开发的嵌入式用户应用.CYW20706采用最先进的40 nm CMOS低功耗工艺,具有最高的集成度,从而消除所有关键外接元件,使得实现蓝牙解决方案具有最小化器件占位面积和最低成本.器件和蓝牙核指标V.4.2包括BR/EDR/BLE兼容,Broadcom专有的LE数据速率高达2Mbps,主要用在家庭自动化,POS输入设备,血压监视器,“Find me”设备,心率监视仪,温度计,可穿戴设备和接近传感器.本文介绍了CYW20706主要特性,功能框图,以及评估板CYW920706WCDEVAL主要特性,框图和布局和元件位置图,电路图,材料清单和PCB设计图.
CYW20706 is a monolithic, single chip, Bluetooth (BT) dual-mode System-on-a-Chip (SoC) that includes a baseband processor, an ARM® Cortex™-M3 processor and an integrated transceiver. It is a fully embedded device running an embedded BT stack with support for embedded user applications developed with WICED Studio.
The Cypress CYW20706 is a single-chip Bluetooth 4.2-compliant, stand-alone baseband processor with an integrated 2.4 GHztransceiver. Manufactured using the industry’s most advanced 40 nm CMOS low-power process, the CYW20706 employs the highestlevel of integration to eliminate all critical external components, thereby minimizing the device ’s footprint and the costs associated withimplementing Bluetooth solutions.
查看全文
