Öйúµç×Ó¼¼ÊõÍø
ÉèΪÊ×Ò³ ÍøÕ¾µØÍ¼ ¼ÓÈëÊÕ²Ø
[Ô­´´] On Semi NCV7685 12·60mA LEDÏßÐÔµçÁ÷Çý¶¯½â¾ö·½°¸
¹Ø¼ü´Ê£ºµçÔ´¹ÜÀí Æû³µµç×Ó LEDÇý¶¯Æ÷ PWM NCV7685
ʱ¼ä£º2020-03-11 11:06:34       À´Ô´£ºÖеçÍø
On Semi¹«Ë¾µÄNCV7685ÊÇ12·60mA LEDÏßÐÔµçÁ÷Çý¶¯Æ÷,¾ßÓй²Í¨»ù×¼µÄ¿É±àºã¶¨µçÁ÷Ô´.²ÉÓÃPWM¼¼Êõ,Æ÷¼þ¾ßÓÐ128¸ö¿Éµ÷ÕûµÄÕ¼¿Õ±È,ͨ¹ýI2C´®¿Ú¿É±à³Ì,ÓÃÓÚÿ¸öÊä³öͨ·.PWMƵÂÊÓÐËÄÖÖ²»Í¬ÅäÖÃ,¸ß´ï1200Hz.Æ÷¼þ¿Éͨ¹ýI2C×ÜÏß»ò¶ÀÁ¢Ó¦ÓÃģʽºÍ΢¿ØÖÆÆ÷Ó¦ÓÃ.Æ÷¼þ»¹Ìṩ3.3Vµçѹ»ù×¼,¸ºÔصçÁ÷¸ß´ï1mA.LEDÁÁ¶ÈÓÐÍâ½Óµç×èÀ´½øÐбà³Ì.ÿ·ÓÐÄÚ²¿µç·À´¼ì²â¿ªÂ·Ìõ¼þ,²¢¿ÉÑ¡Ôñ×Ô¶¯»Ö¸´Ä£Ê½.Èç¹ûÒ»¸öÇý¶¯Æ÷ÔÚ¿ªÂ·Ìõ¼þ,ËùÓÐÆäËü·½«¸ù¾Ý±à³ÌλÉ趨µÄ¶Ï¿ª.Ö÷ÒªÓÃÔÚÆû³µÒDZíÅÌ,ºó×éºÏµÆ(RCL),ÈÕ¼äÔËÐеÆ(DRL),ÎíµÆ,ÖÐÑë¸ßλɲ³µµÆ(CHMSL)ÕóÁÐ,תÏòµÆºÍÆäËüÍⲿ°²×°Ó¦ÓÃ. ÖеçÍøÎªÄúÕûÀíÈçÏÂÏêϸ×ÊÁÏ,±¾ÎĽéÉÜÁËNCV7685Ö÷ÒªÌØÐÔ,¿òͼºÍÓ¦Óÿòͼ,ÒÔ¼°ÆÀ¹À°åNCV7685GEVBÖ÷ÒªÌØÐÔ,µç·ͼ,²ÄÁÏÇåµ¥ºÍPCBÉè¼ÆÍ¼.
12 Channels 60 mA LED Linear Current Driver I2C Controllable for Automotive Applications
The NCV7685 consists of twelve linear programmable constant current sources with common reference. The part is designed for use in the regulation and control of LED for automotive applications. The NCV7685 allows 128 different duty cycle levels adjustable using pulse width modulation (PWM) independently for each output channel programmable via I2C serial interface. PWM frequency can be chosen in four different configurations up to 1200 Hz. The device can be used with micro−controller applications using the I2C bus or in stand−alone applications where a choice could be done in between 2 different static configuration settings. The IC also provides 3.3 V voltage reference to the application for..
²é¿´È«ÎÄ
  • ·ÖÏíµ½£º
²ÂÄãϲ»¶
