[原创] ADI AD74413R四通道软件可配置输入/输出解决方案
关键词:工业控制 过程控制 工厂自动化 马达驱动 建筑物控制系统 AD74413R
时间:2019-12-20 11:00:37       来源:中电网
ADI公司的AD74413R是用于建筑物和过程控制应用的四通道可软件配置输入/输出解决方案.AD74413R包含了模拟输出,模拟输入,数字输入,电阻温度检测器(RTD)和热电偶测量以及串行外设接口(SPI).器件具有16位Σ-Δ模数转换器(ADC)和四个可配置13位数模转换器(DAC),提供四个可配置输入/输出通路和一套诊断功能.器件的模式包括低矮压输出,电流输出,电压输入,外部供电电流输入,回路供电电流输入,外部RTD测量,数字输入逻辑以及回路供电数字输入.AD74413R还包括高精度2.5V内部基准电压用来驱动DAC和ADC.工作温度−40℃ 至 +105℃,64 引脚 LFCSP封装.主要用在工业控制,过程控制,工厂自动化,马达驱动,建筑物控制系统.本文介绍了AD74413R主要特性,功能框图和详细功能框图,电阻测量配置图,数字输入逻辑模式配置图以及评估板EV-AD74413RSDZ主要特性,电路图,材料清单和PCB设计图.
The AD74413R is a quad-channel software configurable input/output solution for building and process control applications. The AD74413R contains functionality for analog output, analog input, digital input, resistance temperature detector (RTD), and thermocouple measurements integrated into a single chip solution with a serial peripheral interface (SPI). The device features a 16-bit, Σ-Δ analog-to-digital converter (ADC) and four configurable, 13-bit digital-to-analog converters (DACs) to provide four configurable input/output channels and a suite of diagnostic functions. There are several modes related to the AD74413R. These modes are voltage output, current output, voltage input, externally powered current input, loop powered current input, external R..
查看全文
