[原创] Rohm C型全SiC模块评估方案BSMGD3C12D24-EVK001
关键词:SiC模块 栅极驱动
时间:2019-11-04 11:09:43       来源:中电网
Rohm公司的BSMGD3C12D24-EVK001是C型全SiC模块评估方案,包含了最佳和安全驱动SiC模块所有必需的元首.包括栅极驱动器,隔离的电源,短路保护,电源电压欠压保护,栅极驱动正偏压欠压保护,栅极驱动正偏压过压保护,高边和低边同时导通保护,控制输出ON/OFF.提供故障信号和温度监视输出.主要应用高温工作环境如飞机发动机,汽车发动机等以及微波应用,军用武器系统,航空航天,石油地质勘探等.本文介绍了评估板BSMGD3C12D24-EVK001主要特性,功能框图以及评估板BSMGD3C12D24-EVK001特性表,电路图,材料清单和PCB设计图.
Evaluation Board for C-type Full SiC Module
This evaluation board, BSMGD3C12D24-EVK001, is a gate driver board for full SiC Modules in C type housing. This evaluationboard contains all the necessary components for optimal and safety driving the SiC module.
图1.评估板BSMGD3C12D24-EVK001和SiC模块外形图
评估板BSMGD3C12D24-EVK001主要特性:
● Gate Drive
● Integrated isolated power supply
● Short Circuit Protection
● Under Voltage Protection (Power Supply Voltage)
● Under Voltage Protection (Gate Drive Positive bias Voltage)
● Over Voltage Protection (Gate Drive Positive bias Voltage)
● High-Side and Low-Side Simultaneous conduction prevention
● Control output ON/OFF
● Fault signal
● Temperature monitoring output
图2. 评估板BSMGD3C12D24-EVK001功能框图
评估板BSMGD3C12D24-EVK001特性表:
图3.用于栅极电阻和软关断电阻外设电路
图4.高边电路图
图5.底边电路图..
查看全文
