[原创] Power Integrations TinySwitch-4 12W电源参考设计RDR-839
关键词:电源管理 AC/DC转换器 PWM MOSFET
时间:2019-09-17 13:49:45       来源:中电网
Power Integrations公司的TinySwitch-4系列是具有电源控制器的高压功率MOSFET开关.和通常的PWM控制器不同,它采用简单的ON/OFF控制来调整输出电压.该控制器包括一个振荡器,使能电路(检测和逻辑),限流状态机,5.85V稳压器, BYPASS/MULTI-FUNCTION引脚,欠压和过压电路,以及限流选择电路,超温保护电路,限流电路,内置前沿消隐电路和725V功率MOSFET.开态UV阈值±5%,通过BP/M电容值可选择更高的限流值,更低的限流值提高封闭适配器/充电器的效率,扩展DRAIN和所有其它引脚的爬电距离,从而提高了现场可靠性,具有极好的能量效率EcoSmart™,容易满足所有全球的能效条例,带偏压线圈的无负载功耗小于30mW,265VAC无偏压线圈无负载功耗小于150mW,主要用在PC待机和其它辅助电源,DVD/PVR和其它低功率机顶译码器,家用电器,工业告警和计量设备的电源,以及手机和无绳电话,PDA,数码相机,MP3/手持音频设备的充电器/适配器.本文介绍了TinySwitch-4产品亮点,功能框图,以及采用TinySwitch-4系列TNY290PG的12W电源参考设计主要指标,电路图,变压器电路图和构造图,以及材料清单和PCB设计图.
TinySwitch-4 combines a high-voltage power MOSFET switch with a power supply controller in one device. Unlike conventional PWM (pulse width modulator) controllers, it uses a simple ON/OFF control to regulate the output voltage.
The controller consists of an oscillator, enable circuit (sense and logic), current limit state machine, 5.85 V regulator, BYPASS/MULTI-FUNCTION pin undervoltage, overvoltage circuit, and current limit selection circuitry, over-temperature protection, current limit circuit, leading edge blanking, and a 725 V power MOSFET. TinySwitch-4 incorporates additional circuitry for line undervoltage sen..
查看全文
