[原创] ST PM8804以太网加电PD转换器4V 8A解决方案
关键词:电源管理 以太网加电 PoE PWM IEEE802.3.af/at/bt
时间:2019-05-16 11:24:24       来源:中电网
ST公司的PM8804以太网加电PD转换器是PWM控制器(峰值电流模式),集成了设计用于PoE和电信中等功率智能和有效48V应用所有需要的电路.PD转换器具有5V 8A输出,具有同步反激,与IEEE802.3bt标准兼容.PM8804具有可编程振荡器,用于开关频率,可调斜率补偿,双互补的具有可编死区时间,可编软起动,软关断和可编电流检测消隐时间(高达200ns)的低边驱动器.其内部高压线性稳压器具有典型20mA输出电流,使得器件能以最少化外接元件来起动.输入工作电压高达75V,栅极驱动器1A峰值电流,最大占空比80%,CTL引脚上的内部上拉电阻可连接光耦合器,工作电流消耗小于1.5mA,主要用于PoE加电设备如IP电话,WLAN接入点和网络照相机以及电信电源.本文介绍了PM8804主要特性,内部框图,应用电路图和以太网加电评估板STEVAL-POE002V1主要特性,电路图和材料清单.
The PM8804 is a PWM controller that integrates all the circuitry required to design a smart and efficient 48 V converter for PoE and telecom mid-power applications.
It features a programmable oscillator for the switching frequency, adjustable slopecompensation, dual complementary low-side drivers with programmable dead time,programmable soft-start, soft turn off and a programmable current sense blanking time.
An internal high-voltage linear regulator with a typical 20 mA output current allows the device to start up with a minimum of external components.Complementary 1 A peak gate drivers make possible to implement high power topologies,while when the second drives is not used, like with simple low power flyback converters, it can be turned off.
The device embed..
查看全文
