[原创] Rohm BD57121MUF-M汽车NFC兼容无线功率发送解决方案
关键词:汽车电子 无线功率发送 NFC AEC-Q100规范
时间:2019-02-11 10:59:57       作者:Rohm       来源:中电网
Rohm公司的BD57121MUF-M是汽车NFC兼容无线功率发送器评估板,包括了ROHM公司的汽车级(AEC-Q100规范)无线功率发送控制IC(BD57121MUF-M)和ST公司的NFC阅读器IC(ST25R3914)以及8位MCU(STM8A系列),兼容WPC的Qi标准,充电高达15W,多线圈设计加宽了充电范围(比单线圈大2.7倍),输入电压11.0-13.0V,输出电压12.0V(接收边),输出电流1.25A(接收边).本文介绍了评估板BD57121MUF-M主要特性和性能指标,无线功率传输和NFC的系统配置图以及评估板BD57121MUF-M主要元件,框图,连接图,电路图,材料清单和PCB设计图.
ROHM has recently announced the development of an automotive wireless charging solution with integrated NFC communication. This solution combines ROHM’s automotive-grade (AEC-Q100 qualified) wireless power transmission control IC (BD57121MUF-M) with STMicroelectronics’NFC Reader IC (ST25R3914) and 8-bit microcontroller (STM8A series). In addition to being compliant to WPC’s Qi standard supporting EPP (Extend Power Profile) that enables the charger to supply up to 15W of power, the multi-coil design enables a wide charging area that provides some spatial freedom in vehicle applications (2.7x greater charging range vs single coil configurations). This means that consumers do not need to worry much about exactly aligning their smartphones to the provided charging area in order to be able to charge wirelessly.
查看全文
