关键词:蓝牙5 无线片上系统(S0C) 物联网(IoT) 可穿戴 能量收获 血糖仪(BGM)
时间:2018-12-05 11:24:38 作者:On Semi 来源:中电网
On Semi公司的RSL10是蓝牙5规范多协议无线片上系统(S0C),具有双核架构和2.4GHz收发器,提供业界最低功耗,支持蓝压低功率和2.4GHz专用或定制协议,可使超低功耗蓝牙应用到无线应用如心率监视仪具有先进的无线特性而有最佳的系统尺寸和电池寿命.RSL10采用1.2V和1.5V电池,发送功率-17到+6dBm,RX接手灵敏度-94dBm,数据速率52.5-2000kbps,主要用在IoT前节点应用,蓝牙低功耗技术,可穿戴,能量收获,血糖仪(BGM).本文介绍了RSL10主要特性,框图和架构图及其主要单元,应用电路,以及开发板与评估板和开发板主要特性,电路图,材料清单和PCB设计图.
RSL10 is a Bluetooth 5 certified, multi-protocol radio System on Chip (SoC) which brings ultra-low-power Bluetooth Low Energy towireless applications.
Offering the industry’s lowest power consumption, RSL10 helps provide devices like heart rate monitors with advanced wirelessfeatures while optimizing system size and battery life.
Unlike most other multi-protocol radio SoCs, RSL10 is specifically designed for applications using 1.2 and 1.5 V batteries, andsupports a voltage supply range between 1.1 and 3.3 V without a required DC/DC converter. The highly-integrated radio SoCfeatures a dual-core architecture and a 2.4 GHz transceiver, providing the flexibility to support Bluetooth Low Energy and 2.4 GHzproprietary or custom protocols.
分享到:
