[原创] ST STSPIN840两个双向有刷DC马达同时驱动方案
关键词:马达驱动 有刷DC马达 工业自动化 服务机器人 STSPIN840
时间:2018-09-28 14:25:58       作者:ST       来源:中电网
ST公司的STSPIN840是紧凑的有刷DC马达驱动器,能同时驱动两个双向有刷DC马达,在4 x 4 mm QFN封装上集成了两个控制逻辑和全保护低RDSon两个全桥功率级,工作电压从7V到45V,最大输出电流1.5Arms,全保护包括非耗散过流保护,短路保护,欠压锁住和热关断.主要用在工业自动化和服务机器人,医疗和保健,ATM,舞台照明,热打印机,纺织和缝纫机,销售机以办公和家庭自动化.本文介绍了STSPIN840主要特性,框图,应用框图和电路,以及马达驱动扩展板X-NUCLEO-IHM15A主要特性,电路图和材料清单.
The STSPIN840 is a compact brushed DC motordriver able to drive two bi-directional brushed DCmotors simultaneously. It integrates, in a verysmall 4 x 4 mm QFN package, both the controllogic and a fully protected low RDSon dual fullbridgepower stage.
Thanks to a dedicated PARALLEL input pin theparallel mode function can be enabled,transforming the device in an equivalent andmore powerful single full-bridge able to deliver upto 3Arms current at an equivalent HS + LS RDSonof 500 mohm.
The STSPIN840 embeds two independent PWMcurrent controllers (one for each full bridge) basedon user settable values of reference voltage andOFF time.The devices can be forced in a low consumptionstate reducing the total current consumption downto less than 45uA.
查看全文
