[原创] On Semi RSL10蓝牙5多协议无线片上系统(SoC)解决方案
关键词:无线通信 蓝牙5 无线片上系统(SoC) 可穿戴 物联网(IoT) 汽车电子
时间:2018-09-26 10:53:24       作者:On Semi       来源:中电网
On Semi公司的RSL10是包含了内置天线,无线电和所需所有无源器件的系统封装器件(SIP),获得蓝牙特别兴趣小组(SIG)认证,无需任何额外的射频(RF)设计考量,大大减少了上市时间和开发成本,可实现每秒2兆位 (Mbps)的速度与业界最低功耗,深度睡眠模式下的功耗仅62.5纳瓦(nW),峰值接收功耗仅7毫瓦(mW),主要用IoT边沿节点应用兵,可穿戴设备,能量收获,健身跟踪/活动监测,家用电器,智能手表,心率监视器,血糖仪,脉搏血氧计,智能锁和汽车应用.本文介绍了RSL10主要特性,以及评估板RSL10−002GEVB主要特性,电路图,材料清单和PCB元件布局图.
RSL10 is a Bluetooth 5 certified, multi-protocol radio System on Chip (SoC) which brings ultra-low-power Bluetooth Low Energy to wireless applications.
Offering the industry’s lowest power consumption, RSL10 helps provide devices like heart rate monitors with advanced wireless features while optimizing system size and battery life.
Unlike most other multi-protocol radio SoCs, RSL10 is specifically designed for applications using 1.2 and 1.5 V batteries, and supports a voltage supply range between 1.1 and 3.3 V without a required DC/DC converter. The highly-integrated radio SoC features a dual-core architecture and a 2.4 GHz transceiver, providing the flexibility to support Bluetooth Low Energy and 2.4 GHz proprietary or custom protocols.
RSL10主要特性:
Ultra-Low-Power:
- Industry’s lowest power consu..
查看全文
