[原创] NXP MPC5775BE汽车电池管理系统(BMS)解决方案
关键词:汽车电子 电池管理系统(BMS) e200z7 MCU
时间:2018-08-03 11:34:54       作者:NXP       来源:中电网
NXP公司的MPC5775B和MPC5775E MCU是用于汽车和逆变器的电池管理系统(BMS),提供先进的性能,安全性和支持ASIL-D.具有2个Power Architecture z7内核,MPC5775E频率高达264 MHz,MPC5775B 频率高达220 MHz,1个z7内核与其中一个主内核同步,集成了 4 MB闪存,512 KB SRAM以及CSE硬件安全模块,支持SHE协议规范和AES-128加密,具有10/100Mbps以太网模块和2个CAN-FD 模块和4个FlexCAN模块,高达70通道eQADC和32通道eMIOS,主要用在需要先进性能,安全性和ASIL-D支持的汽车和工业电池管理和逆变器应用.本文介绍了MPC5775B和MPC5775E主要特性,MPC5775E框图以及评估板MCU主板和子板MPC5775BE-416DS主要特性,功能框图,MPC5775BE-416DS子板电路图.
The MPC5775B and MPC5775E microcontrollers target automotive and industrial battery management and inverter applications that require advanced performance, security, and ASIL-D support.
These MCUs are compatible with the MPC5777C device and offer customers an optimized feature set for the targeted applications. The MPC5775B and MPC5775E provide an ideal migration path for customers using MPC5xx, MPC55xx, MPC5644A and MPC5674F with eTPU timer and similar pin count options.
MPC5775BE主要特性:
• Three dual issue,32-bit CPU core complexes(e200z7),two of which run in lockstep
• Power Architecture embedded specification compliance..
查看全文
