[原创] Microchip ATA6570高速案CAN收发器解决方案
关键词:汽车电子 CAN 控制器区域网络 ATA6570
时间:2018-06-04 10:30:59       作者:Microchip       来源:中电网
Microchip公司的ATA6570是单独可用具有局部网络的高速控制器区域网络(CAN)收发器,完全和ISO 11898-2, ISO11898-5, ISO11898-6, ISO/DIS 11898-2 (2016)以及SAEJ2962-2兼容,标准CAN数据速率高达1Mbps,CAN FD数据速率高达5Mbps(CAN FD),4Mbps SPI接口,能直接和3.3V-5V MCU接口,主要用在汽车环境.本文介绍了ATA6570主要特性,框图,以及ATAB657XA开发板主要特性,电路图,材料清单和PCB设计图.
The Atmel® ATA6570 is a standalone high speed CAN transceiver that interfaces a Controller Area Network (CAN) protocol controller and the physical two wire CAN bus designed for high speed CAN applications in the automotive environment.
It provides local and enhanced remote wake-up capabilities and is available in a SO14 package. The Atmel ATA6570 has a very low power consumption in Standby and Sleep Mode. Beside local wake-up via WAKE and remote wake-up pattern according to ISO 11898-5, ATA6570 additionally supports ISO11898-6 compliant CAN partial networking. A CAN frame decoder evaluates the bus traffic and checks for a matching frame, that has being configured into registers via the SPI. The device is able to keep the complete ECU in a low power mode even when bus traffic is present until a valid wake-up frame is received. It also features a watchdog and a Serial Peripheral Interface (SPI).
查看全文
