[原创] Cypress FM4-176L-S6E2GM32位MCU开发方案
关键词:ARM Cortex-M4F MCU 马达控制
时间:2017-05-24 10:36:04       作者:Cypress       来源:中电网
Cypress公司的FM4-176L-S6E2GM是高度集成基于ARM Cortex-M4F处理器的 32位MCU,片上具有高达1MB闪存和192KB SRAM.器件包括了高端通信模块如IEEE 1588兼容的以太网,CAN,基于硬件的密码辅助模块,串行通信接口(USB,UART,CSIO(SPI),I2C,LIN)以及先进的控制外设如马达控制计时器,ADC和正交位置/旋转计数器.CPU工作频率180MHz,工作电压2.7-V 到5.5-V,主要用在通信设备和马达控制.本文介绍了FM4-176L-S6E2GM产品亮点,系列框图以及FM4-176L-S6E2GMPioneer开发套件主要特性,开发板主要元件分布图以及电路图和材料清单.
S6E2G-Series are highly-integrated 32-bit microcontrollers with high performance and competitive cost. This series is based on the ARM Cortex-M4F processor with on-chip flash memory and SRAM. The portfolio includes high end communication modules such as IEEE 1588 compliant Ethernet, CAN, a hardware-based cryptographic assist module, serial communication interfaces (USB, UART, CSIO (SPI), I2C, LIN) and advanced control peripherals such as motor control timers, A/D converters, and a quadrature position/revolution counter.
FM4-176L-S6E2GM产品亮点:
High-Performance MCU Subsystem
608 CoreMark®, 180-MHz ARM® Cortex®-M4 CPU
244-µA/MHz active current with 2.7-V to 5.5-V operating voltage
Up to 1MB flash and 192KB SRAM with a 16KB flash accelerator..
查看全文
