[原创] Renesas RX65N MCU入门开发方案
关键词:RXv2 CPU 马达控制 物联网(IoT) RX65N
时间:2017-05-02 10:57:29       作者:Renesas       来源:中电网
Renesas公司的RX65N是采用32位RXv2 CPU核的高性能MCU,最大工作频率120MHz,在120MHz时的性能240DMIOS,单精度32位IEEE-754浮点,嵌入了90nm和40nm快速存储器,在核处理,代码效率和功耗上具有极好的性能,片上还集成了混合信号外设,工作电压2.7到3.6-V,主要用在物联网连接和马达控制等.本文介绍了RX65N主要特性,框图,以及RX65N入门开发板(RSK)主要特性和指标,框图,元件布局图,电路图和材料清单.
RX65N, RX651 group are highly compatible among the same series both in functional scalability and pin assignments.
In addition, driver/middleware (FIT support) and sample code-generation tools (code generators) and evaluation boards (starter kits) to allow reuse of most of developed hardware/software resources, enabling seamless and scalable product development from small to large scale applications without effort in a short-time.
RX65N主要特性:
■ 32-bit RXv2 CPU core
 Max. operating frequency: 120 MHz
Capable of 240 DMIPS in operation at 120 MHz
 Single precision 32-bit IEEE-754 floating point
 Two types of multiply-and-accumulation unit (between memoriesand between registers)
 32-bit multiplier (fastest instruction execution takes one CPU clockcycle)
 Divider (fastest instruction execution takes two CPU clock cycles)
 Fast interrupt..
查看全文
