[原创] Cypress FM4 S6E2C系列32位MCU以太网开发方案
关键词:ARM Cortex-M4 以太网 CAN USB FM4 S6E2C
时间:2016-07-27 14:07:33       作者:Cypress       来源:中电网
Cypress公司的FM4 S6E2C系列是基于ARM® Cortex®-M4的高度集成的32位MCU, 集成了闪存和SRAM,以及包括马达控制计时器,ADC和通信接口(USB, CAN, UART, CSIO (SPI), I2C, LIN)的外设,以及硬件加密引擎(AES-128/192/256, SHA-256, PKA).工作频率200MHz.本文介绍了FM4 S6E2C系列主要特性和框图,开发板FM4-216-ETHERNE主要特性和框图,电路图和PCB设计图.
Devices in the S6E2CCSeries are highly integrated 32-bit microcontrollers with high performance and competitive cost.This series is based on the ARM Cortex-M4F processor with on-chip flash memory and SRAM. The serieshasperipherals such as motor control timers, A/Dconverters,and communicationsinterfaces (USB, CAN, UART, CSIO (SPI), I2C, LIN).The productsthatare described in this data sheet are placed into TYPE3-M4 product categories "FM4 Family Peripheral ManualMain Part (002-04856)."
查看全文
