[原创] ST STM8S003F3风扇遥控参考设计
关键词:8位MCU STM8 马达控制 家用电器 STM8S003F3
时间:2015-12-24 16:59:44       作者:ST        来源:中电网
ST公司的STM8S003F3/K3系列是提供8KB闪存程序存储器和数据EEPROM的8位微控制器(MCU),工作频率16MHz,采用哈佛架构和三级流水线,具有可靠的I/O,单独看门狗和不同的时钟源以及时钟安全系统.本文介绍了STM8S003F3/K3主要特性,功能框图,以及基于单路TRIAC的风扇速度遥控板STEVAL-IHM037V1主要特性,电路图和材料清单.
The STM8S003F3/K3 value line 8-bit microcontrollers offer 8 Kbytes of Flash program memory, plus integrated true data EEPROM. They are referred to as low-density devices in the STM8S microcontroller family reference manual (RM0016).
TheSTM8S003F3/K3 value line devices provide the following benefits: performance, robustness and reduced system cost.
Device performance and robustness are ensured by true data EEPROM supporting up to 100000 write/erase cycles, advanced core and peripherals made in a state-of-the-art technology at 16 MHz clock frequency, robust I/Os, independent watchdogs with separate clock source, and a clock security system.
The system cost is reduced thanks to a high system integration level with internal clock oscillators, watchdog, and brown-out reset.
STM8S003F3/K3主要特性:
Core
16 MHz advanced STM8 core with Harvard architecture and 3-stage pipeline
Extended instruction set
Memories..
查看全文
