[原创] Cypress FM4 S6E2CC 32位MCU开发方案
关键词:ARM Cortex-M4F MCU 马达控制 以太网 USB CAN LIN
时间:2015-12-11 10:51:09       作者:Cypress       来源:中电网
Cypress公司的FM4 S6E2CC是基于32位ARM Cortex-M4F处理器的高度集成微控制器(MCU),集成了片上闪存和SRAM存储器,以及诸如马达控制计时器,ADC,通信接口(USB, CAN,UART, CSIO (SPI), I2C, LIN)等外设,CPU工作频率200MHz,具有性能和成本优势,主要用在工业领域和通信行业.本文介绍了FM4 S6E2CC主要特性,框图,以及FM4-216-ETHERNET S6E2CC开发平台主要特性,电路图和开发板PCB设计图.
Devices in the S6E2CC Series are highly integrated 32-bit microcontrollers with high performance andcompetitive cost.
This series is based on the ARM Cortex-M4F processor with on-chip flash memory and SRAM. The serieshas peripherals such as motor control timers,A/D converters, and communications interfaces (USB, CAN,UART, CSIO (SPI), I2C, LIN).
FM4 S6E2CC主要特性:
32-bit ARM Cortex-M4F Core
 Processor version: r0p1
 Up to 200 MHz frequency operation
 FPU built-in
 Support DSP instructions
 Memory protection unit (MPU): improves the reliability of an embedded system
 Integrated nested vectored interrupt controller (NVIC): 1 NMI (non-maskable interrupt) and 128 peripheralinterrupts and 16 priority levels
 24-bit system timer (Sys Tick): system timer for OS task management
On-chip Memories
 Flash memory..
查看全文
