[原创] Cypress PSoC 4200系列ARM MCU评估方案
关键词:ARM Cortex™-M0 MCU PSoC 4 PSoC 4200系列
时间:2015-09-02 15:31:38       作者:Cypress       来源:中电网
Cypress公司的PSoC 4200系列是基于ARM® Cortex™-M0 MCU的混合信号可编程系统控制器,拥有速度更快的处理器,更高的ADC采样速度以及基于PLD的增强型通用数字模块(UDB).器件包括有可编程和可重新配置的模拟和数字区块,其32位MCU子系统工作频率高达48MHz,32kB闪存和4kB SRAM,工作电压1.71V 到5.5V,多达36个可编GPIO,适应更广泛的应用开发需求.本文介绍了PSoC 4200系列主要特性,框图,以及FM4-U120-9B560 FM4 MCU评估板主要特性和电路图.
PSoC® 4 is a scalable and reconfigurable platform architecture for a family of mixed-signal programmable embedded systemcontrollers with an ARM® Cortex™-M0 CPU. It combines programmable and reconfigurable analog and digital blocks with flexible automatic routing. The PSoC 4200 product family, based on this platform, is a combination of a microcontroller with digital programmablelogic, high-performance analog-to-digital conversion, opamps with Comparator mode, and standard communication and timingperipherals. The PSoC 4200 products will be fully upward compatible with members of the PSoC 4 platform for new applications anddesign needs. The programmable analog and digital sub-systems allow flexibility and in-field tuning of the design.
PSoC 4200系列主要特性:
32-bit MCU Sub-system
■ 48-MHz ARM Cortex-M0 CPU with single cycle multiply..
查看全文
