[原创] TI ADS1262 32位Delta-Sigma模数转换器评估方案
关键词:模数转换器 ADC 仪器仪表 分析仪器 温度和压力测量仪 ADS1262
时间:2015-08-10 11:38:25       作者:TI       来源:中电网
TI公司的ADS1262是32位低噪音低漂移38.4-kSPS Delta-Sigma (ΔΣ) ADC,集成了PGA,基准电压和内部故障监视器,数据速率2.5 SPS 到38400 SPS,失调1 nV/℃,增益漂移 0.5 ppm/℃,线性度3ppm,噪音7 nVRMS (2.5 SPS,增益= 32),主要用在高分辨率PLC,温度和压力测量仪,称重仪和应力表,分析仪器,图表记录仪和面板表.本文介绍了ADS1262主要特性,框图,温度补偿桥式测量电路图以及评估板ADS1262EVM主要特性,电路图和材料清单.
The ADS1262 and ADS1263 are low-noise, low-drift, 38.4-kSPS, delta-sigma (ΔΣ) ADCs with an integrated PGA, reference, and internal fault monitors. The ADS1263 integrates an auxiliary, 24-bit, ΔΣ ADC intended for background measurements. The sensor-ready ADCs provide complete, high-accuracy, one-chip measurement solutions for the most-demanding sensor applications, including weigh scales, strain-gauge sensors, thermocouples, and resistance temperature devices (RTD).
The ADCs are comprised of a low-noise, CMOS PGA (gains 1 to 32), a ΔΣ modulator, followed by a programmable digital filter. The flexible analog front-end (AFE) incorporates two sensor-excitation current sources suitable for direct RTD measurement.
A single-cycle settling digital filter maximizes multiple-input conversion throughput, while providing 130-dB rejection of 50-Hz and 60-Hz line cycle interference.
查看全文
