[原创] TI RF430FRL15xH 13.56MHz传感器转发器评估方案
关键词:RFID NFC FRAM MCU 物联网 穿载设备 工业应用 RF430FRL15xH
时间:2014-12-19 09:18:56       作者:TI       来源:中电网
TI公司的RF430FRL15xH是集成了16位MSP430低功耗MCU的13.56MHz 传感器转发器,具有嵌入通用的FRAM非易失存储器,通过ISO/IEC 15693, ISO/IEC 18000-3兼容的RFID接口和SPI/I2C接口支持通信,参数设定和配置.传感器测量由内部温度传感器和14位ADC进行,数字传感器通过SPI或I2C来连接,主要用在物联网,穿载设备,工业应用等领域.本文介绍了RF430FRL15xH主要特性,框图和应用电路与相应的材料清单,以及评估模块RF430FRL152HEVM主要特性,框图和电路图.
The RF430FRL15xH device is a 13.56-MHz transponder chip with a programmable 16-bit MSP430 low-power microcontroller. The device features embedded universal FRAM nonvolatile memory for storage of program code or user data such as calibration and measurement data. The RF430FRL15xH supports communication, parameter setting, and configuration through the ISO/IEC 15693, ISO/IEC 18000-3 compliant RFID interface and the SPI or I2C interface. Sensor measurements are supported by the internal temperature sensor and the onboard 14-bit sigma-delta analog-to-digital converter (ADC), and digital sensors can be connected through SPI or I2C.
查看全文
