关键词:无线通信 物联网 蓝牙 Wi-Fi 家用电器 工业和家庭自动化 智能网关
时间:2014-11-21 14:28:19 作者:TI 来源:中电网
TI公司的WL1837MOD是双频带(2.4GHz和5GHz)Wi-Fi模块解决方案,具有两个天线,符合FCC, IC,ETSI/CE和TELEC标准,操作系统包括Linux®, Android™, WinCE和RTOS.器件集成了RF,功率放大器,时钟,RF开关,滤波器,无源元件和电源.Wi-Fi部分支持IEEE Std 802.11a, 802.11b,802.11g和802.11n标准,蓝牙支持Bluetooth 4.1和CSA2,工作温度–40℃到85℃,主要用在物联网,多媒体,家用电子,家用电器和白色家电,工业和家庭自动化,智能网关,视频会议,视频相机等.本文介绍了WL1837MOD主要特性和优势,功能框图,系统应用框图,参考电路和材料清单,以及评估板WL1837MODCOM8I EVB主要特性,电路图,材料清单和四层PCB设计图.
The certified WiLink 8 module from TI offers high throughput and extended range along with Wi-Fi and Bluetooth coexistence (WL1837MOD only) in a power-optimized design. The WL18x7MOD is a Wi-Fi, dual-band, 2.4- and 5-GHz module solution with two antennas supporting Industrial temperature grade. The device is FCC, IC, ETSI/CE, and TELEC certified for AP (with DFS support) and client. TI offers drivers for high-level operating systems, such as Linux®, Android™, WinCE, and RTOS.
WL1837MOD主要特性和优势:
General
Integrates RF, Power Amplifiers (PAs), Clock, RF Switches, Filters, Passives, and Power
Management
Quick Hardware Design With TI Module
Collateral and Reference Designs
Operating Temperature: –40℃ to 85℃
Industrial Temperature Grade..
分享到:
