Infineon XMC4500 ARM Cortex-M4 MCU系列评估方案
关键词:ARM Cortex-M4 MCU 工业控制 数字电源 马达控制 工业连接
时间:2014-08-12 09:38:07       作者:Infineon       来源:中电网
Infineon公司的XMC4500系列产品是基于ARM Cortex-M4处理核的32位工业MCU,适用于数字电源,马达控制, 工业连接和传感与控制应用.本文介绍了XMC4500主要特性,框图, 马达控制框图,以及评估板XMC4500 Relax/Relax Lite Kit-V1主要特性,框图,电路图,PCB元件分布图和材料清单.
The XMC4500 series belongs to the XMC4000 family of industrial microcontrollers based on the ARM Cortex-M4 processor core. The XMC4000 series devices are optimized for electrical motor control, power conversion, industrial connectivity and sense & control applications.
The growing complexity of today’s energy efficient embedded control applications are demanding microcontroller solutions with higher performance CPU cores featuring DSP (Digital Signal Processing) and FPU (Floating Point Unit) capabilities as well as integrated peripherals that are optimized for performance. Complemented with a development environment designed to shorten product development time and increase productivity, the XMC4500 series of microcontrollers take advantage of Infineon’s decades of experience in microcontroller design, providing an optimized solution to meet the performance challenges of today’s embedded control applications.
查看全文
