xilinx公司的Zynq®-7000是全编程SoC器件,是系统级集成电路,并具有硬件,软件和I/O可编程性,可设计更智能化的系统,大大地降低BOM成本,NRE成本,设计风险,同时加快产品面市.主要用在工业控制,马达驱动,测试和测量,嵌入式视角系统以及软件定义无线电和嵌入系统模块.本文介绍了Zynq®-7000系列特性,框图以及MicroZed开发电路板主要特性,框图,电路图和材料清单.
The Zynq®-7000 All Programmable SoCs are available in -3, -2, and -1 speed grades, with -3 having the highest performance. Zynq-7000 device DC and AC characteristics are specified in commercial, extended, and industrial temperature ranges. Except the operating temperature range or unless otherwise noted, all the DC and AC electrical parameters are the same for a particular speed grade (that is, the timing characteristics of a -1 speed grade industrial device are the same as for a -1 speed grade commercial device). However, only selected speed grades and/or devices are available in the commercial, extended, or industrial temperature range.
All supply voltage and junction temperature specifications are representative of worst-case conditions. The parameters included are common to popular designs and typical applications
图1. Zynq-7000方框图
MicroZed™ is a low-cost development board based on the Xilinx Zynq®-7000 All Programmable SoC. Its unique design allows it to be used as both a stand-alone evaluation board for basic SoC experimentation, or combined with a carrier card as an embeddable system-on-module (SOM). MicroZed contains two I/O headers that provide connection to two I/O banks on the programmable logic (PL) side of the Zynq®-7000 AP SoC device. In stand-alone mode, these 100 PL I/O are inactive. When plugged into a carrier card, the I/O are accessible in a manner defined by the carrier card design.
MicroZedTM 是一款基於Xilinx Zynq®-7000 全可編程系統級芯片的低成本開發電路板。它的獨特設計讓其既可以被用作單獨的基本SoC實驗用的評估板,也可以與基板組合,用作嵌入式系統化模塊(SOM)。 MicroZed 包括兩個I/O 接頭,在Zynq®-7000 AP SoC器件的可編程邏輯(PL) 端可以連接到兩個I/O bank。在獨立工作下,這100個P L I/O是閒置的。在插入基板後,這些I/O 可以按照基板設計所定義的方式訪問。因此設計師可以從MicroZed獨立工作開始,熟悉和了解這個平台;之後就可以很方便地通過增加一塊現成的或用戶設計的基板,來將其功能擴展為系統級模塊。這種獨立工作/SOM相結合的方法可以很快地將設計構思從概念轉到投產,使MicroZed 成為基於SoC應用的理想平台。
套件包括:
MicroZed 電路板
Micro USB 電纜線
4 GB μSD 卡
Xilinx Vivado® WebPACK™ 許可證及邏輯分析儀軟件(鎖定使用器件)
快速入門文件
图2. MicroZed开发电路板外形图
图3. MicroZed开发电路板框图
MicroZed开发电路板主要特性:
SoC
XC7Z010-1CLG400C
存儲器
»»1 GB of DDR3 SDRAM
»»128 Mb of QSPI Flash 存儲器
»»Micro SD 卡接口
通信
»»10/100/1000 以太網
»»USB 2.0
»»USB-UART
用戶I/O (通過兩個闆對板連接器)
»»100 個用戶I/O (每個連接器50個)
»»最多可配置48對LVDS或100 個單端I/O
其它
»»2x6 Digilent Pmod® 兼容的接口,為用戶I/O提供8 PS MIO 連接
»»Xilinx PC4 JTAG 配置端口
»»可以通過 Pmod 訪問 PS JTAG 引腳
»»33.33 MHz 振盪器
»»用戶 LED 和按鍵開關
目標應用
»»應用 Zynq®-7000 AP SoC 評估和原型設計
»»嵌入式系統化模塊 (SOM) 應用
»»嵌入式視覺系統
»»測試 & 測量
»»電機控制
»»軟件定義無線電
图4. MicroZed开发电路板电路图(1)
图5. MicroZed开发电路板电路图(2)
图6. MicroZed开发电路板电路图(3)
图7. MicroZed开发电路板电路图(4)
图8. MicroZed开发电路板电路图(5)
图9. MicroZed开发电路板电路图(6)
图10. MicroZed开发电路板电路图(7)
图11. MicroZed开发电路板电路图(8)
MicroZed开发电路板材料清单:
详情请见:
http://www.xilinx.com/support/documentation/data_sheets/ds187-XC7Z010-XC7Z020-Data-Sheet.pdf
和
http://www.microzed.org/sites/default/files/documentations/MicroZed_HW_UG_v1_1.pdf
以及http://www.microzed.org/sites/default/files/documentations/MicroZed_RevF_Schematic_131029_PRELIMINARY.PDFds187-XC7Z010-XC7Z020-Data-Sheet.pdf
PB-AES-Z7MB-7Z010-G - Chinese Version.pdf
