ADI 数字输出陀螺仪解决方案
关键词:内置温度校准 角速率传感器 ADXRS450
时间:2013-09-11 10:10:57       作者:ADI       来源:中电网
Keywords:built-in temperature calibration , yaw-axis rate sensing  , ADXRS450
摘要: ADXRS450是一个数字输出,单轴陀螺仪,内置的温度校准。EVAL-ADXRS450Z针对ADXRS450应用设计,使得ADXRS450能够方便地连接到现有的系统。
基本特点: ADXRS450是一款角速率传感器(陀螺仪),主要用于工业、医疗、仪器仪表、稳定和其它高性能应用。它采用先进的差分四路传感器设计,可抑制线性加速度的影响,能够在极其恶劣的冲击和振动环境中工作。
ADXRS450采用内部连续自测架构。机电系统的完整性通过以下方法来检查:对检测结构施加一个高频静电力,以便产生一个速率信号,将该速率信号与基带速率数据区分开来,并进行内部分析。
ADXRS450能够检测高达±300°/s的角速率。角速率数据以16位字的形式提供,作为32位SPI消息的一部分。ADXRS450提供16引脚空腔塑封SOIC (SOIC_CAV)和SMT兼容垂直贴装(LCC_V)两种封装,能够在3.3 V至5 V的宽电压范围内和−40°C至+105°C的温度范围内工作。
方案描述:
The EVAL-ADXRS450Z-V is a simple breakout board that facili-tates quick evaluation of the performance of the ADXRS450 ±300°/sec digital output single-axis rate gyroscope in an SMT-compatible vertical mount package.
The EVAL-ADXRS450Z-V has two sets of 5-lead, 0.1-inch pin spacing headers that allow electrical connections to be made between the ADXRS450 and the existing system. Four mounting holes are also provided for mechanical attachment of the EVAL-ADXRS450Z-V to the application. An external host processor is required for communication to the ADXRS450 gyroscope.
查看全文
