时间:2012-09-28 09:24:12 作者:ST 来源:STEVAL
ST公司的STEVAL-IHM036V1低功率马达控制板采用SLLIMM™ STGIPN3H60和 基于ARM® Cortex™-M3的MCU STM32F100C6T6B,最低输入电压275VDC或195VAC,最大输入电压375VDC或265VAC,输出功率高达100W,具有过流硬件保护和基于NTC电阻的超温保护,目标应用包括家庭热水泵,洗碗机马达和电冰箱压缩机.本文介绍了STGIPN3H60主要特性,框图,典型应用电路以及低功率马达控制板STEVAL-IHM036V1主要特性,电路图,材料清单和PCB元件布局图.
This intelligent power module implements a compact, high performance AC motor drive in a simple, rugged design. It is composed of six IGBTs with freewheeling diodes and three halfbridge HVICs for gate driving, providing low electromagnetic interference (EMI) characteristics with optimized switching speed. The package is optimized for thermal performance and compactness in built-in motor applications, or other low power applications where assembly space is limited. This IPM includes an operational amplifier, completely uncommitted, and a comparator that can be used to design a fast and efficient protection circuit. SLLIMM™ is a trademark of STMicroelectronics.
STGIPN3H60主要特性:
■ IPM 3 A, 600 V, 3-phase IGBT inverter bridge including control ICs for gate driving and freewheeling diodes
■ Optimized for low electromagnetic interference
分享到:
