Fairchild FAN6756 65W笔记本电脑电源解决方案
关键词:电源管理 AC/DC转换器 开关电源 SMPS
时间:2012-08-23 10:09:01       作者:Fairchild       来源:FAN6756
Fairchild 公司的FAN6756是采用创新mWSaver™技术的绿色模式PWM控制器,能大大地降低待机和无负载功耗,满足世界范围的待机模式效率指引.在230VAC时待机和无负载功耗为30mW(包括EMI滤波器功耗),具有多种保护如过载/开路保护(OLP),UVLO,VDD OVP,超温保护(OTP)和电流检测短路保护(SSCP),主要用于笔记本电脑,打引机,LCD监视器,游戏机控制台.本文介绍了FAN6756主要特性,方框图,典型应用电路以及FAN6765MR评估板指标,电路图,材料清单和PCB元件布局图.
The FAN6756 is a next-generation Green Mode PWM controller with innovative mWSaver™ technology, which dramatically reduces standby and no-load power consumption, enabling conformance to worldwide Standby Mode efficiency guidelines.
An innovative AX-CAP™ method minimizes losses in the EMI filter stage by eliminating the X-cap discharge resistors while meeting IEC61010-1 safety requirements. Standby Mode clamps feedback voltage and modulates feedback impedance with an impedance
modulator during Burst Mode operation, which forces the system to operate in a “deep” Burst Mode with minimum switching losses.
查看全文
