Powerint LNK302 150W LED街灯照明参考设计(RDR-292)
关键词:电源管理 LED驱动器 开关电源 AC/DC转换器
时间:2012-05-03 10:58:44       作者:Powerint       来源:LNK302
Powerint公司的150W LED街灯照明参考设计(RDR-292)采用LinkSwitch-TN系列的LNK302和HiperPFS与HiperLCS系列产品,组合了PFS功率系数级和LCS输出级,输入电压90 VAC - 265 VAC,100%负载和50%负载时的功率系数大于0.9.本文介绍了LNK302产品亮点,方框图以及150W LED街灯照明参考设计主要特性与指标,电路图,材料清单和PCB布局图.
Reference Design Report for a 150 W Power Factor Corrected LLC Power Supply for LED Street Lighting
LinkSwitch-TN is specifically designed to replace all linear and capacitor-fed (cap dropper) non-isolated power supplies in the under 360 mA output current range at equal system cost while offering much higher performance and energy efficiency.
查看全文
