ST STM32F103ZGT6 32位ARM Cortex-M3 MCU开发评估方案
关键词:工业控制 马达控制 PLC 变频器;医疗电子
时间:2012-04-28 10:31:55       作者:ST       来源:STM32F103ZGT6
ST公司的STM32F103x4和STM32F103x6是基于ARM Cortex™-M3的32位RISC核的MCU,工作频率72MHz,集成了16或32KB闪存,USB,CAN,6个定时器,2个ADC和六个通信接口.电源电压2.0V-3.6V,有两种温度范围: –40到+85 ℃和–40 to到+105 ℃.主要用在马达驱动,工业应用,医疗和手持设备,PC和游戏外设,GPS平台,PLC,逆变器,打印机,扫描仪和HVAC等.本文介绍了STM32F103x4和STM32F103x6主要特性,方框图,以及STM3210E-EVAL评估板主要特性,方框图,电路图和PCB元件布局图.
STM32F103x4和STM32F103x6: Low-density performance line, ARM-based 32-bit MCU with 16 or 32 KB Flash, USB, CAN, 6 timers, 2 ADCs, 6 communication interfaces
The STM32F103x4 and STM32F103x6 performance line family incorporates the highperformance ARM Cortex™-M3 32-bit RISC core operating at a 72 MHz frequency, highspeed embedded memories (Flash memory up to 32 Kbytes and SRAM up to 6 Kbytes), and an extensive range of enhanced I/Os and peripherals connected to two APB buses. All devices offer two 12-bit ADCs, three general purpose 16-bit timers plus one PWM timer, as well as standard and advanced communication interfaces: up to two I2Cs and SPIs, three USARTs, an USB and a CAN.
查看全文
