NXP SSL2103 14W可调光LED驱动方案
关键词:电源管理 LED驱动器 AC/DC转换器 开关电源 SMPS
时间:2012-03-23 10:13:12       作者:NXP       来源:SSL2103
NXP公司的SSL2103是用于LED照明的可调光Greenchip控制器, 适合于反激和降压配置应用.器件支持大多数的调光解决方案,具有最佳的效率,中性调光曲线可对数修正到1%,超温保护(OTP),绕组短路保护(SWP)和过流保护(OCP).本文介绍了SSL2103主要特性和优势,方框图,亮度控制框图,降压和反激配置应用电路图,以及SSL2103演示板主要指标,230 V (AC)14 W A55 LED 反激电路图和材料清单.
SSL2103: Dimmable Greenchip controller for LED lighting
The SSL2103 is a Switched Mode Power Supply (SMPS) controller IC that operates in combination with a phase cut dimmer directly from the rectified mains. It is designed to drive LED devices. The device includes a circuit to allow direct start-up from the rectified mains voltage.
For dimmer applications, an integrated dedicated circuitry optimizes the dimming curve.
• SSL2101: fully integrated LED driver for lamps up to 10 W
• SSL2102: fully integrated LED driver for lamps up to 25 W
• SSL2103: gives the application designer flexibility to:
Use an external power switch to allow the IC to provide any power
– Use an external bleeder transistors to provide extended dimmer interoperability
SSL2103主要特性和优势:
 Easy migration to existing lighting control infrastructure
 Supports most available dimming solutions..
查看全文
