Hitex NXP LPC2929 BLDC和步进马达控制解决方案
关键词:工业控制 马达控制 BLDC 步进马达
时间:2012-02-24 11:17:48       作者:Hitex       来源:NXP LPC2929
NXP公司的LPC2926/2927/2929是集成了ARM968E-S CPU核和工作频率高达125MHz的两个TCM区块,全速USB 2.0 OTG和器件控制器,CAN和LIN,56KB SRAM以及高达768KB闪存,外接存储器接口,三个10位ADC和多个串行和并行接口。而Hitex公司的BLDC马达控制板能驱动直流无刷马达(BLDC)和电压范围15V-24V/1A的步进马达。本文介绍了LPC2926/2927/2929主要特性和优势,方框图,以及MCEB-DC马达控制板框图,电路图和PCB元件布局图。
The LPC2926/2927/2929 combines an ARM968E-S CPU core with two integrated TCM blocks operating at frequencies of up to 125 MHz, Full-speed USB 2.0 OTG and device controller, CAN and LIN, 56 kB SRAM, up to 768 kB flash memory, external memory interface, three 10-bit ADCs, and multiple serial and parallel interfaces in a single chip targeted at consumer, industrial and communication markets. To optimize system power consumption, the LPC2926/2927/2929 has a very flexible Clock Generation Unit (CGU) that provides dynamic clock gating and scaling.
LPC2926/2927/2929主要特性和优势:
􀂄 ARM968E-S processor running at frequencies of up to 125 MHz maximum.
􀂄 Multi-layer AHB system bus at 125 MHz with four separate layers.
􀂄 On-chip memory:
􀂋 Two Tightly Coupled Memories (TCM), 32 kB Instruction TCM (ITCM), 32 kB Data TCM (DTCM).
查看全文
