ST STEVAL-ISV008V1 300W光伏电池转换器解决方案
关键词:电源管理 太阳能逆变器 DC/DC转换器
时间:2011-12-21 10:47:46       作者:ST        来源:STEVAL-ISV008V1
ST公司的STEVAL-ISV008V1是采用SPV1020的300W光伏电池转换器,是PWM模式的DC/DC升压转换器,工作电压0-40V,效率高达98%,MPPT算法占空比控制精度0.2%,内置软起动,具有过压,过流和过温保护,RoHS兼容.本文介绍了SPV1020主要特性,方框图,应用电路以及STEVAL-ISV008V1评估板主要特性,方框图,电路图和材料清单.
SPV1020 is a monolithic DC-DC boost converter designed to maximize the power generated by photovoltaic panels independently of temperature and amount of solar radiation.
The optimization of the power conversion is obtained with an embedded logic which performs the MPPT (max power point tracking) algorithm on the PV cells connected to the converter.
One or more converters can be housed in the connection box of PV panels, replacing the bypass diodes, and thanks to the fact that the maximum power point is locally computed, the efficiency at system level will be higher than the one of conventional topologies, where the MPP is computed in the main centralized inverter.
查看全文
