Avago AEAT-6600-T16 16位可编程角度磁编码解决方案
关键词:工业控制 马达驱动 机器人 工厂自动化
时间:2011-10-09 11:18:00       作者:Avago       来源:AEAT-6600-T16
Avago公司的 AEAT-6600是10- 16位可编程无接触磁旋转编码器,工作电压5V或3.3V,绝对值输出3线或2线SSI接口模式,绝对值10位到16位分辨率,增量输出分辨率8-1024CPR,主要用无刷DC马达的3相转子,替代电子分解器和电位计,工业自动化和机器人。本文介绍了AEAT-6600主要特性和指标,方框图以及OTP编程模式和对准模式电路图,AEAT-6600-T16磁编码器编程器套件主要特性:
AEAT-6600-T16:10 to16-Bit Programmable Angular Magnetic Encoder IC
The Avago AEAT-6600 angular magnetic encoder IC is a contact less magnetic rotary encoder for accurate angular measurement over a full turn of 360 degrees. It is a system-on-chip, combining integrated Hall elements, analog front end and digital signal processing in a single device.
To measure the angle, only a simple two-pole magnet, rotating over the center of the chip, is required. The magnet may be placed above or below the IC.
The absolute angle measurement provides instant indication of the magnet’s angular position with a resolution of 0.005° = 65 536 positions per revolution. This digital data is available as a serial bit stream and as a PWM signal.An internal voltage regulator allows the AEAT-6600 to operate at either 3.3 V or 5 V supplies.
AEAT-6600主要特性:
5 V or 3.3 V operation
查看全文
