TI TPS92210 PFC LED照明驱动解决方案
关键词:电源管理 AC/DC转换器 LED驱动器 PFC LED
时间:2010-11-11 10:56:11       作者:TI       来源:TPS92210
TI 公司的TPS92210 是功率因素控制器(PFC) LED照明驱动控制器,它的PWM调制算法可随开关频率和初级电流而变,同时保持不连续或瞬态模式工作,具有高的效率和低的EMI,开路LED检测等.主要用在TRIAC可调光LED照明设计,住宅区LED照明和道路照明等.本文介绍了TPS92210主要特性,功能方框图,典型应用电路以及TPS92210EVM-613评估板主要性能和指标,电路图和材料清单(BOM).
The TPS92210 is a natural power factor correction (PFC) light emmitting diode (LED) lighting driver controller with advanced energy features to provide high efficiency control for LED lighting applications.
A PWM modulation algorithm varies both the switching frequency and primary current while maintaining discontinuous or transition mode operation in all regions of operation. The TPS92210 cascode architecture enables low switching loss in the primary side and when combined with the discontinuous conduction mode (DCM) operation ensures that there is no reverse recovery loss in the output rectifier. These innovations result in efficiency, reliability or system cost improvements over a conventional flyback architecture.
TPS92210主要特性:
Flexible Operation Modes
Constant On-Time Enables Single Stage PFC Implementation
Peak Primary Current
Cascoded MOSFET Configuration
查看全文
