Diode ZXLD1370 60V LED驱动方案
关键词:电源管理 LED驱动器 DC/DC转换器
时间:2010-05-28 11:31:40       作者:Diode       来源:中电网
Diode公司的ZXLD1370是60V高精度降压/升压/升降压LED驱动控制器,输出电流精度0.5%,工作电压6V-60V,DC调光比20:1,500Hz的调光比达1000:1,工作频率高达1MHz,可驱动超过15个串联的LED.本文介绍了ZXLD1370主要特性, 降压配置框图, 升压/升降压配置框图, OVP保护电路,和2.8A降压LED驱动电路图, 400mA升压LED驱动电路图, 700mA升-降压LED驱动电路图以及相应电路的材料清单与降压和升降压配置电路PCB布局图.
ZXLD1370:60V HIGH ACCURACY BUCK/BOOST/BUCK-BOOST LED DRIVER CONTROLLER
The ZXLD1370 is an LED driver controller IC for driving external MOSFETs to drive high current LEDs. It is a multitopology controller enabling it to efficiently control the current through series connected LEDs. The multi-topology enables it to operate in buck, boost and buck-boost configurations.
The 60V capability coupled with its multi-topology capability enables it to be used in a wide range of applications and drive in excess of 15 LEDs in series.
The ZXLD1370 is a modified hysteretic controller using a patent pending control scheme providing high output current accuracy in all three modes of operation. High accuracy dimming is achieved through DC control and high frequency PWM control.
查看全文
