PowerInt TOP265EG 30W待机电源参考设计
关键词:电源管理 AC/DC转换器
时间:2010-05-28 11:37:06       作者:PowerInt       来源:中电网
PowerInt 公司的TOPSwitch-JX系列(TOP264-271)集成了725V功率MOSFET,高压开关电流源,多模式PWM控制,热关断电路,故障保护和其它控制电路, 265 VAC电压下无负载的功耗低于100mW.本文介绍了TOPSwitch-JX系列(TOP264-271)主要特性, 方框图, 通用输入高效19V 65W反激电源电路图和采用TOP265EG的12V 30W高效待机电源设计案例的电路图和所用材料清单.
TOPSwitch-JX TOP264-271 cost effectively incorporates a 725 V power MOSFET, high voltage switched current source, multi-mode PWM control, oscillator, thermal shutdown circuit, fault protection and other control circuitry onto a monolithic device.
TOPSwitch-JX 系列主要特性:
EcoSmart® - Energy Efficient
• Energy efficient over entire load range
• No-load consumption below 100 mW at 265 VAC
• Up to 750 mW standby output power for 1 W input at 230 VAC
High Design Flexibility for Low System Cost
• Multi-mode PWM control maximizes efficiency at all loads
• 132 kHz operation reduces transformer and power supply size
• 66 kHz option for highest efficiency requirements
• Accurate programmable current limit
• Optimized line feed-forward for line ripple rejection
• Frequency jittering reduces EMI filter cost
查看全文
