NXP LPC1311 Cortex-M3 CPU USB接口方案
关键词:计算机与外设 USB接口
时间:2010-05-11 14:10:20       作者:NXP       来源:中电网
NXP LPC1311/13/42/43 是基于Cortex-M3 的微控制器,具有高度集成和低功耗,可用于嵌入式应用。CPU工作频率高达72MHz,单电源2.0V-3.6V工作,内置了嵌套中断向量控制器(NVIC),多达32KB闪存,多达8KB数据存储器,USB设备,快速模式I2C总线接口,一个UART,四个通用定时器和多达42个GPIO引脚。主要应用在电子测量,照明,告警系统和白色家电。本文介绍了LPC1311/13/42/43主要特性,方框图,时钟发生方框图以及自供电USB接口框图和总线供电USB接口框图。
The LPC1311/13/42/43 are ARM Cortex-M3 based microcontrollers for embedded applications featuring a high level of integration and low power consumption. The ARM Cortex-M3 is a next generation core that offers system enhancements such as enhanced debug features and a higher level of support block integration.
The LPC1311/13/42/43 operate at CPU frequencies of up to 72 MHz. The ARM Cortex-M3 CPU incorporates a 3-stage pipeline and uses a Harvard architecture with separate local instruction and data buses as well as a third bus for peripherals. The ARM Cortex-M3 CPU also includes an internal prefetch unit that supports speculative branching.
The peripheral complement of the LPC1311/13/42/43 includes up to 32 kB of flash memory, up to 8 kB of data memory, USB Device (LPC1342/43 only), one Fast-mode Plus I2C-bus interface, one UART, four general purpose timers, and up to 42 general purpose I/O pins.
查看全文
