Mimix XU1019-QH 37-40GHz上变换方案
关键词:通信技术 上变换器 MMIC LMDS VSAT
时间:2010-01-26 10:41:00       来源:Mimix
Mimix Broadband 公司的XU1019-QH是37-40GHz高度集成的QFN封装的上变换器,变换增益7dB,IIP3为+20dBm,镜像抑制大于15dBc.器件包括LO倍频器和缓冲器,RF缓冲器以及镜像抑制(平衡)混频器,可变增益和可调偏压.主要用在微波点对点无线电,LMDS,SATCOM和VSAT等.本文介绍XU1019-QH主要特性, 功能方框图和典型应用配置框图, 应用框图和评估板布局图.
XU1019-QH Delivers +20 dBm IIP3 and 7 dB Conversion Gain
Mimix Broadband’s 37.0-40.0 GHz GaAs MMIC Intergrated Up-converter that has a typical conversion gain of 7 dB, and an image rejection of greater than 15 dBc. It has been optimized for USB operation. The device includes a LO doubler and buffer, and can be tuned to give 2xLO leakage of less than -25 dBm. Variable gain regulation can be achieved by adjusting the bias, with turn-down trajectories optimized to maintain linearity and minimal 2xLO leakage over the gain control range. At full gain, an IIP3 of 20 dBm is typical. The device comes in an RoHS compliant 4x4mm QFN surface mount package offering excellent RF and thermal properties. Typical application for this device are as an up-converter stage in a linear 38GHz radio transmit lineup. They device is well suited for Millimeter-wave Point-to-Point Radio, LMDS, SATCOM and VSAT applications.
XU1019-QH主要特性:
查看全文
