TI 公司的bq3060是全集成的单片锂离子电池管理器,能对2,3,或4组锂离子电池进行电量计量,保护和身份验证.采用超低功耗模式的8位RISC CPU,可用于上网本/笔记本电脑,医疗和测试设备以及手提仪表.本文介绍bq3060主要特性, 系统分区方框图和评估板bq3060EVM-001电路图和材料清单.
The Texas Instruments bq3060 Battery Manager is a fully integrated, single-chip, pack-based solution that provides a rich array of features for gas gauging, protection, and authentication for 2, 3, or 4 series cell Li-Ion battery packs. With a footprint of merely 7.8mmx6.4mm in a compact 24-pin TSSOP package, the bq3060 maximizes functionality and safety while dramatically cutting the solution cost and size for smart batteries.
Using its integrated high-performance analog peripherals, the bq3060 measures and maintains an accurate record of available capacity, voltage, current, temperature, and other critical parameters in Li-Ion or Li-Polymer batteries, and reports the information to the system host controller over an SMBus 1.
bq3060主要特性:
Advanced CEDV (Compensated End-of-Discharge Voltage) Gauging
Fully Integrated 2,3, and 4 Series Li-Ion or Li-Polymer Cell Battery Pack Manager
8-Bit RISC CPU With Ultra-Low Power Modes
分享到:
