Maxim MAX2044 2.3-4GH z上下变换混频方案
关键词:通信技术 LTE WiMAX MMDS
时间:2009-11-10 10:44:00       来源:Maxim
Maxim 公司的MAX2044是高线性2.3-4GHz上/下变换混频器,输入IP3为+32.5dBm,噪音为8.5dB, 2.3-4GHz的转换损耗为7.7dB,可用在2.5GHz WiMAX和LTE 基站,2.7GHz MMDS基站,3.5GHz WiMAX 和LTE基站,固定宽带无线接入,WLL,私人移动无线电和军用系数.本文介绍MAX2044主要特性,方框图, 上/下变换模式元件表以及应用电路图.
The MAX2044 single, high-linearity upconversion/down­conversion mixer provides +32.5dBm input IP3, 8.5dB noise figure, and 7.7dB conversion loss for 2300MHz to 4000MHz LTE, WiMAXK, and MMDS wireless infra­structure applications. With an ultra-wide 2600MHz to 4300MHz LO frequency range, the MAX2044 can be used in either low-side or high-side LO injection archi­tectures for virtually all 2.5GHz and 3.5GHz applications.
In addition to offering excellent linearity and noise performance, the MAX2044 also yields a high level of component integration. This device includes a double-balanced passive mixer core, an LO buffer, and on-chip baluns that allow for single-ended RF and LO inputs. The MAX2044 requires a nominal LO drive of 0dBm, and supply current is typically 138mA at VCC = 5.0V or 121mA at VCC = 3.3V.
查看全文
