TI公司的AM273x系列Sitara MCU是高度集成高性能基于Arm Cortex-R5F和 C66x浮点DSP核的微控制器.器件能使初始设备制造商(OEM)和原始设计制造商(ODM)以强健软件支持,丰富用户接口和高性能,通过最大限度全集成混合处理器解决方案把产品快速推向市场.
TI公司的AM273x系列Sitara™ MCU是高度集成高性能基于Arm Cortex-R5F和 C66x浮点DSP核的微控制器.器件能使初始设备制造商(OEM)和原始设计制造商(ODM)以强健软件支持,丰富用户接口和高性能,通过最大限度全集成混合处理器解决方案把产品快速推向市场.器件的处理器系统集成双核Arm® Cortex®-R5F MCU子系统,工作频率高达400MHz, 双核Arm® Cortex®-R5集群支持双核和单核操作,单核和双核每个集群具有128KB TCM.器件还集成了TMS320C66x DSP核,是单核32位浮点DSP,工作频率450MHz(14.4GMAC),存储器子系统有多达5.0MB片上RAM(OCSRAM),存储器空间可在DSP,MCU和共享L3间分享, 3.5625MB共享L3,960KB专用主子系统,384KB专用DSP子系统,外接存储器QSPI接口工作高达67MHz.高度存储器接口包括10/100Mbps以太网(RGMII/RMII/MII),输入为2x 4路MIPI D-PHY CSI 2.0数据,输出为4路Aurora/LVDS.主要用在机器人,工厂自动化安全防卫,建筑物自动化,汽车音频,交通监视,机器视觉,航空电子学和工业运输.本文介绍了AM273x系列主要特性,功能框图, 案例电路图以及评估模块AM273x EVM主要特性,电路图,材料清单和PCB部分设计图.
The AM273x family of microcontrollers is a highly-integrated, high-performance microcontroller based on the Arm Cortex-R5F and a C66x floating-point DSP cores. The device enables Original-Equipment Manufacturers (OEM) and Original-Design Manufacturers (ODM) to quickly bring to market devices with robust software support, rich user interfaces, and high performance, through the maximum flexibility of a fully integrated, mixed processor solution.
With an integrated Hardware Security Module (HSM) and functional safety support built in, large, integrated RAM on die and a wide temperature range, the AM273x offers a safe, secure and cost effective solution for many industrial and automotive applications.
The AM273x device is provided as part of a complete platform solution including hardware reference designs, software drivers, DSP library, sample software
configurations/applications, API guide, and user documentation.
AM273x系列主要特性:
Processor Cores:
• Dual-co...
