[原创] Cypress S6AL211四路40W LED智能照明系统解决方案
关键词:电源管理 LED驱动器 LED 照明 智能照明 S6AL211
时间:2018-10-17 11:28:17       作者:Cypress       来源:S6AL211
Cypress公司的S6AL211是用于智能照明的四路LED驱动器,为商业照明,住宅照明和其它照明系统提供最优化的解决方案.输入电压VIN DC 24V,输出功率72W,效率大于 94 %.器件可依靠通信以及各种感应器来对应调光和调色,削减BOM 成本.本文介绍了S6AL211主要特性,框图和应用框图和电路,以及40W智能LED 驱动板S6SAL211A94SA1001主要指标,电路图,材料清单和PCB设计图.
There are possible to the light dimming and tune colors control of 4 ch. LED strings. This device can be dimming and toning for 4 ch.LEDs. The dimming and color control is corresponded to communication interfaces and sensors. Through it can use for not only thegeneral lighting but also office, shop and residence lighting control systems. Moreover, S6AL211 series integrate a 3V-LDO regulatorcircuit for supplying the power to the peripheral circuits. It contributes to the BOM cost reduction. S6AL211 series can offer the bestsolution according to your usage.
S6AL211主要特性:
 Control of up to 4 channels LED strings (such as Red, Green, Blue, White or White×4 etc.)
 Input voltage range VIN: DC 24 V (Absolute Maximum rating: 35 V)
 Output power range: 72 W (1A/18 V at LED Vf 3.6 V(typ)×5 / 1 ch. )
 LED brightness control method: LED current control and LED ON/OFF PWM control..
查看全文
