[原创] ST STGIF10CH60TS-L 1kW马达控制电源板解决方案
关键词:电源管理 马达控制
时间:2018-05-23 09:22:34       作者:ST       来源:中电网
ST公司的STGIF10CH60TS-L是小型低损耗智能模塑模块(SLLIMM)第二代IPM,包括了ST专有的控制IC(一个LS和一个HS驱动器)和15A/600V抗短路的IGBT, 3.3V, 5 V TTL/CMOS输入,主要用在3相马达驱动逆变器,以及家用电器如洗衣机,空调,冰箱和缝纫机等.本文介绍了STGIF10CH60TS-L主要特性,框图和应用电路,以及1000W马达控制电源板STEVAL-IPM10F主要特性,电路图和材料清单与PCB设计.
This second series of SLLIMM (small low-loss intelligent molded module) provides a compact, high performance AC motor drive in a simple, rugged design. It combines new ST proprietary control ICs (one LS and one HS driver) with an improved short-circuit rugged trench gate field-stop (TFS) IGBT, making it ideal for 3-phase inverter systems such as home appliances and air conditioners. SLLIMM™ is a trademark of STMicroelectronics.
STGIF10CH60TS-L主要特性:
 IPM 15 A, 600 V 3-phase IGBT inverter bridge including 2 control ICs for gate driving and freewheeling diodes
 3.3 V, 5 V TTL/CMOS inputs with hysteresis
 Internal bootstrap diode
 Undervoltage lockout of gate drivers
 Smart shutdown function
 Short-circuit protection
 Shutdown input/fault output
 Separate open emitter outputs
 Built-in temperature sensor ..
查看全文
