时间:2017-05-08 10:19:49 作者:Intersil 来源:中电网
Intersil公司的ISL85014是14A高效同步降压稳压器,输入电压3.8V到18V,采用电流模式控制,具有快速响应和极好的回路稳定性.器件集成了非常低ON态电阻的高边和低边FET,以最大化效率和最小化外接元件数量,输出电流高达14A,PWM输出电压从0.6V起可调,主要用在服务器和云基础结构POL,IPC,工厂自动化,PLC,通信和网络系统,存储系统以及测试设备.本文介绍了ISL85014主要特性,功能框图和应用框图,以及评估板ISL85014EVAL1Z主要特性和指标,框图,电路图,材料清单和PCB设计图.
The ISL85014 is a highly efficient, monolithic, synchronous buck regulator that can deliver 14A of continuous output current from a 3.8V to 18V input supply. The device uses current mode control architecture with a fast transient response and excellent loop stability.
The ISL85014 integrates very low ON-resistance high-side and low-side FETs to maximize efficiency and minimize external component count. The minimum BOM and easy layout footprint are extremely friendly to space constraint systems.
The operation frequency of this device can be set using the FREQ pin: 600kHz (FREQ = float) and 300kHz (FREQ = GND). The device can also be synchronized to an external clock up to 1MHz.
分享到:
