[原创] Infineon BSC093N15NS5 3kW高压双相LLC电源解决方案
关键词:电源管理 双相LLC DC/DC转换器 BSC093N15NS5
时间:2017-03-01 11:09:34       作者:Infineon       来源:中电网
Infineon公司的BSC093N15NS5是新型OptiMOS™ 5 150 V功率MOSFET,具有更低的R DS(on) ,更低的输出充电,超低反向恢复充电,主要用在低压驱动,通信和太阳能设备.本文介绍了BSC093N15NS5主要特性和优势, 3kW双相LLC评估板EVAL_3kW_2LLC_C7主要特性,控制板电路图和PCB设计图.
The new OptiMOS™ 5 150 V power MOSFETs from Infineon are particularly suitable for low voltage drives such as forklift and e-scooter, as well as telecom and solar applications. The new products offer a breakthrough reduction in R DS(on) (up to 25 percent compared to the next best alternative in SuperSO8) and Q rr without compromising FOM gd and FOM OSS, effectively reducing design effort whilst optimizing system efficiency. Furthermore, the ultra-low reverse recovery charge (Q rr = 26 nC in SuperSO8) increases commutation ruggedness.
BSC093N15NS5主要特性:
Lower R DS(on) without compromising FOM gd and FOM oss
Lower output charge
Ultra-low reverse recovery charge
Increased commutation ruggedness
Higher switching frequency possible
BSC093N15NS5优势:
Reduced paralleling
Size reduction enabled with SuperSO8 best-in-class
Higher power density designs
More rugged products
System cost reduction..
查看全文
