Linear公司的LTC6811是多达12个串接的多个电池组监测器,总测量误差小于1.2mV,电池测量范围0-5V,所有12个电池在290us内测量完.多个LTC6811器件可串联,以测量更长高电压的电池串.每个LTC6811具有isoSPI接口,用来高速RF免疫长距离通信.主要用在电动和混合动力汽车,备份电池系统,电网能量存储以及大功率手持设备.本文介绍了LTC6811主要特性,LTC6811-1和LTC6811-2框图,应用电路以及演示板DC2260A主要特性和电路图.
The LTCR6811 is a multicell battery stack monitor thatmeasures up to 12 series connected battery cells witha total measurement error of less than 1.2mV. The cellmeasurement range of 0V to 5V makes the LTC6811suitable for most battery chemistries. All 12 cells can bemeasured in 290μs, and lower data acquisition rates canbe selected for high noise reduction.
Multiple LTC6811 devices can be connected in series, permittingsimultaneous cell monitoring of long, high voltagebattery strings. Each LTC6811 has an isoSPI interface for
high speed, RF-immune, long distance communications.
Using the LTC6811-1, multiple devices are connected ina daisy chain with one host processor connection for alldevices. Using the LTC6811-2, multiple devices are connectedin parallel to the host processor, with each deviceindividually addressed.
..分享到:
